braiding twisting tig wire, for art/jewelry?
发表于 2021-8-31 22:49:52 | 显示全部楼层 |阅读模式
I have seen this done on lots of belt buckles rings bracelets etc. I have made a few attempts but I can't seem to get the same look… anyone ever do this? Do you have any pointers? thanks! Like this pic from AWS Facebook page earlier.https://fbcdn-sphotos-h-a.akamaihd.n...f9eac3d0e2c574- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:they do it with a drill. Put one end of your wires in a vise and the other in the drill and spin.
Reply:that is what i tried…. it wouldn't get that tight twist. I was using 3/32, maybe try 1/16?- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:You have to go slow and keep tension on it. Practice with bailing wire. The stuff they are using is sterling silver, it is a lot more malleable than tig filler.
Reply:Thanks I'll give it another try. See what we get.- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:It looks like the "twist" part of a "haywire twist". I do it by hand all the time, I like to hold the loop side with my left hand and then hold the legs at about a 45 angle from each other near where you want to twist. After you get the hold, just twist it. If I can find some tig wire here at home I will give it a try.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:May need to anneal the wire before doing it.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Originally Posted by SquirmyPugIt looks like the "twist" part of a "haywire twist". I do it by hand all the time, I like to hold the loop side with my left hand and then hold the legs at about a 45 angle from each other near where you want to twist. After you get the hold, just twist it. If I can find some tig wire here at home I will give it a try.
Reply:Tig wire?Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by camjeep3So you use 1 piece
Reply:That's the trick. I had been using two pieces. I got a nice twist with the 3/32 as well as 1/16. The 1/16 stayed straight. The 3/32 got some curve in it. Thanks guys!- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:Preheat with propaneLong after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:Pull hard while twisting to avoid the bending.
Reply:Originally Posted by walkerPull hard while twisting to avoid the bending.
GMT+8, 2025-12-29 09:21 , Processed in 0.098792 second(s), 18 queries .
