500 lbs drawer slides
发表于 2021-8-31 22:49:52 | 显示全部楼层 |阅读模式
I know you can just buy them. I am looking for ideas of a simple way to fabricate them. I am sure it is possible to build them. I have a few ideas but would like to hear from some others here. Thanks
Reply:I have seen some that use a 2" "x 1" x1-8" bar channel and a stem mounted roller. They use a peg behind the front and ahead of the rear roller as a stop.
Reply:Lista uses single roller for their 500 lb drawers. I think it is not a good idea, doubles are better.
Reply:You could use track rollers or cam followers to make your own drawer slides.  Some where I saw ones that fit inside channel iron. I think McMaster Carr has them.Dan D.Manipulator Of Metal
GMT+8, 2025-12-29 11:14 , Processed in 0.100833 second(s), 18 queries .
