F1554 Gr 55 S1 to A572 Gr 50
发表于 2021-8-31 22:49:52 | 显示全部楼层 |阅读模式
Hi,I need to develop a WPS and PQR for F1554 Gr 55 S1 anchor bolts welded to A572 Gr 50 plate.  The bolt holes are thru drilled, with a fillet on the bottom of the plate, and a PJP groove weld on the top, 5/8" deep.  The F1554 is not a pre-qualified material, so I guess its on to Section 4 of D1.1.  To my knowledge, F1554 is not a listed material in Section 4, so all the testing is required.  Basically, my question is this.  In the above joint, how would I prepare a test coupon for tensile testing?Appreciate any input.
GMT+8, 2025-12-29 09:20 , Processed in 0.096838 second(s), 18 queries .
