Tweco Fabgun 250 consumables -> Lincoln @ Home Depot?
发表于 2021-8-31 22:49:43 | 显示全部楼层 |阅读模式
I am thinking about getting a used Tweco Fabgun 250. I'm wondering about consumables, I want easy to access ones. Home Depot sells Lincoln tips and nozzles, anyone know if these fit the standard Tweco guns like the Fabgun 250?Thesehttp://www.homedepot.com/p/t/1003410...6#.UVXXDVci-lgThanksMiller Passport
Reply:Ok looks like Tweco guns in the 200 up range use series 14 consumables, at least that is the the info I have found out right now.Miller Passport
Reply:Yes, the 14's are what you want, but the Home Depot ones are 11's which will not fit.You can easily find them on-line, I get mine from weldingsupply.com, many other places carry them.Lincoln and Tweco tips are interchangeable.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Originally Posted by Silicon-basedLincoln and Tweco tips are interchangeable.John
Reply:Yep, you're right about the Magnum Pro tips. They're... different. JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Originally Posted by Silicon-basedYep, you're right about the Magnum Pro tips. They're... different. John
GMT+8, 2025-12-29 09:10 , Processed in 0.074651 second(s), 18 queries .
