GTAW advice??
发表于 2021-8-31 22:49:42 | 显示全部楼层 |阅读模式
I just started TIG a couple days ago and still cant figure it out, any advice??
Reply:do a search tons of threads if those do not answer your questions then post up a question this is ask about almost once a weekMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Everything you need to know is herehttp://lmgtfy.com/?q=how+to+tig+weldTorchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Please fill out the following form.....your number will be called shortly after it is filled out...MachineAmperageTungsten blend/sizeFiller rod type/sizeArgon Flow CFHAC balance (if applicable)Pulse (if applicable)EP/EN currents/ratios (if applicable)material thicknesspre-weld prep routinetorch size/style + air or water cooledcollet body stylecup stylepre-flow secondspost-flow secondspicture of your sharpened tungsten before AND after running a bead(s)PICTURES/videos of: parts fit-up, torch angle, travel direction, speed descriptionsyou want advice?  You'll get the best advice if we know all that stuff ^^^^ 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Originally Posted by GambleEverything you need to know is herehttp://lmgtfy.com/?q=how+to+tig+weld
Reply:Originally Posted by smilexelectricNot the best way to learn. A lot of those videos are horrible and give bad advice.Here is a good link for good solid infohttp://www.millerwelds.com/resources/tools/spend the money on a good book and dive in.
Reply:Originally Posted by OscarHe didn't just link videos.  That google search actually yielded the Miller Resources webpage as the second search hit.
Reply:Originally Posted by adajroshoI just started TIG a couple days ago and still cant figure it out, any advice??
Reply:What's there to get? Just kidding of course. As others have said, more information and pics are needed. Are you to a point where you can get a puddle established on a flat plate and move it around a bit?
Reply:Originally Posted by WookieWeldingdo a search tons of threads if those do not answer your questions then post up a question this is ask about almost once a week
Reply:And please don't ask a weeks worth of questions and then show your first attempts on a old corroded filthy rusty hunk of a leaf spring that was cut with a torch right where you welded it  First bit of avise would be fresh clean metal with no mill scale on it wiped down clean with acitone for premium results. That will knock out a ton of variables I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeAnd please don't ask a weeks worth of questions and then show your first attempts on a old corroded filthy rusty hunk of a leaf spring that was cut with a torch right where you welded it  First bit of avise would be fresh clean metal with no mill scale on it wiped down clean with acitone for premium results. That will knock out a ton of variables
Reply:Go take a course from a qualified instructor who can teach you the hands on basics including set-ups then put in hours of hood time, there are no short cuts. You can watch videos until hell freezes over and never master the process.Last edited by Old Skool; 03-16-2013 at 05:59 PM.REAL TRUCKS DON'T HAVE SPARK PLUGS
Reply:I have a good handle on it now thanks for the input. The group of welding instructors at lincoln tech in grand prairie texas  are an elite group of welders, best decision in my life thus far was to come here.
GMT+8, 2025-12-29 09:21 , Processed in 0.120271 second(s), 18 queries .
