Argon.
发表于 2021-8-31 22:49:38 | 显示全部楼层 |阅读模式
I pay big bucks for Argon over here and on two occasions I've left the gas tap open. What a waste. My tank sits under the table the machine is on and I think that's where the problem comes in. I was really having trouble with my tig welding about a year ago and no matter what I tried the welds were looking like I had the gas turned off (this was before I left the tap open), I thought it was the material or the tungsten rods but the gas supplier said it might be bad gas. He sold me Crystal Argon touting it as the best. My welds were fine after that. I got a refill that isn't Crystal  last month and the welds are fine. Have any of you experienced bad gas?.
Reply:Just got a fresh argon cylinder myself yesterday.Crystal argon? Can you elaborate on that?Never had bad gas myself, not that it can't happen.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Yep quite a few times.......in twenty years......I keep several bottles on hand....It doesn't take much to contaminate a bottle. It's a good habit to turn off the gas when your done along with bleed off the pressure in your regulators..Last edited by B_C; 03-31-2013 at 07:15 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by snoeproeJust got a fresh argon cylinder myself yesterday.Crystal argon? Can you elaborate on that?Never had bad gas myself, not that it can't happen.
Reply:Stainless does not need a premium argon.  Aluminum might.  Titanium and magnesium certainly does.
Reply:Originally Posted by rlitmanStainless does not need a premium argon.  Aluminum might.  Titanium and magnesium certainly does.
Reply:Argon and all gases come in or have many differen purity or categories. Argon alone can be-Research, Semi Conducter, ICP, UHP, HP, Pre Purified, Purified, so and so on. Never heard of a medical grade of Argon though.
Reply:Originally Posted by DownsouthArgon and all gases come in or have many differen purity or categories. Argon alone can be-Research, Semi Conducter, ICP, UHP, HP, Pre Purified, Purified, so and so on. Never heard of a medical grade of Argon though.
GMT+8, 2025-12-29 09:10 , Processed in 0.097776 second(s), 18 queries .
