Sa-200 Door Latches
发表于 2021-8-31 22:49:32 | 显示全部楼层 |阅读模式
Hi Everyone,I'm looking for a source for the little spring loaded door latches on the side doors of the SA-200s.  Mine are pretty well gone from corrosion and two of the springs have long since rusted away.  Given the option, I would rather go with the original type latch as opposed to adapting something different although that is not totally out of the question if there is something better out there that doesn't look like crap.Dave B.E-MAIL:  [email protected] PAGES:  www.wfmservice.comwww.rides4rides.comwww.pvpmedia.com/53f100.htmDad always said, "If it ain't broke, don't fix it."I say, We can make it better.
Reply:Give Lincoln a call or stop by a LWS. With all the SA200's that have been manufactured, over the years, I'm sure there are quite a few original replacement door latches still in stock, somewhere. Some of the larger LWS usually have a few old SA200's, no longer working, that could be used for parts salvaging.
Reply:Originally Posted by Diverbill45Give Lincoln a call or stop by a LWS.  Some of the larger LWS usually have a few old SA200's, no longer working, that could be used for parts salvaging.
Reply:They seem to be the same (or at least close) to the newer classics.  They should be available thru lincoln.
GMT+8, 2025-12-29 09:20 , Processed in 0.097680 second(s), 18 queries .
