welding cap
发表于 2021-8-31 22:49:32 | 显示全部楼层 |阅读模式
Hi I bought a welding cap via a website from the US about 4 years ago, I am wanting to try and find out where to get another, the name has worn off the label witch is sewn into the peak and I cant remember what it said, it ended in "co" I think.. Its reversible, one side being striped, while the other is block purple. i have had many welding caps in the 20 years Ive been a welder but non as good as the one i have, but alas its staring to wear around the edge,, any help appreciated…. Simon
Reply:I am not sure if it might be a Kroner. My neighbor has one that is reversible and it is a Kroner. I will try to find out where he got it. I do not wear a cap when I weld. Makes my hood fell like it is loose
Reply:Here ya go... I have a Kromer cap from the 80's; best cap I've ever had!http://www.welduk.com/Results1.asp?Category=53You should be able to find other resellers in your part of the world.  Good luck Last edited by ElectroLight; 01-15-2007 at 03:25 PM.That aint heat lightning in the neighborhood tonight...
Reply:When Might I Need To Where A Welding Cap Besides Overhead Work?KISS...KEEP IT SAFE STUPID
Reply:When you get that one piece of flying splatter that catches your hair on fire Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Originally Posted by TIGBOYWhen Might I Need To Where A Welding Cap Besides Overhead Work?
Reply:No its not  a Kromer it was somthing like rasco or weldco, i have had many Kromers but they drop to bits after a while thanks tho!
Reply:Post a picture, that might help ID the mistery cap !Not a beginner, not a pro !
Reply:I have had much better luck with a simple "do rag" like the motorcycle riders wear.  Weiler sells them here and they are much easier to wash and easier to get a good fit than a regular welding cap.
Reply:here,s  A place  www.truckhat.com
Reply:Just received one from this fine Lady.  Good fit, lined and stiff bill.  Can't go wrong withthis one!http://search.ebay.com/_W0QQsassZhatlady1937QQhtZ-1
Reply:Simon, not sure what brand you have, but Roxanne Johnson at http://www.highdeserthats.commakes great fitting and durable hats and doo rags. She custom makes every one to your liking ie: crown height and patterns. worth a look - Bill
Reply:Got one it was a lapco ive found a web site here in the uk that supplies them.. Thanks for all your help  http://www.lapcomfg.com/products/products_caps.html
Reply:The best, most comfortable, well made caps in the world are made by a woman named Suzie, in the US, who travels the country with her husband, a union pipefitter. She can be reached at 719-321-0834, or look at the website at http:suziescaps.com/default.aspx
Reply:I've had a few welding hats but always go back to the old bandana.  The back of my hood hooks around the knot and fits perfect.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Don't get one with flames on it.  Even if it's only for a second or two, you don't want people to look at you and think "Oh, that's just his cap" if your head is actually on fire.Ditto the design with the spiders, too.  You'd never notice the real spider sitting in your cap until after you put it on your head.Pass on the camouflage cap as well.  If you put a camouflage cap down in the yard, you'll never find it.  If you could, then it really wouldn't be camouflaged, would it?Seriously, I'm going to order one from http://suziescaps.com/ next week.  Thanks for the info!
GMT+8, 2025-12-29 11:12 , Processed in 0.104051 second(s), 18 queries .
