wanted spoolmatic 1 2 or 3
发表于 2021-8-31 22:49:32 | 显示全部楼层 |阅读模式
I am looking for a aluminum spoolmatic 1 2 or 3 for an older milliermatic 200  thanks
Reply:I believe you do not want a Spoolmatic II, but it is in stock here. If your MM200 has a 4 pin receptacle, you want a Spoolmatic I - if a later 14 pin, you want a Spoolmatic III, assuming you don't want to get involved in adapting. All are in stock. PM if you like.      weldersales
Reply:I have two Spoolmatic 1 guns and two WC-1 controls, also a S-32S and Millermatic 10E and an Airco Feeder(don't remember model offhand). Which I will be EBay'n soon.
GMT+8, 2025-12-29 09:19 , Processed in 0.098163 second(s), 18 queries .
