Stainless Tables
发表于 2021-8-31 22:49:29 | 显示全部楼层 |阅读模式
I haven't really posted up with any projects I've built yet.  Figure its due time and I just finished building these tables for a customer at work.  Built from 2 x 2 x .120 wall stainless.  Their 2 foot wide, 32" tall with a shelf in the middle, brushed finish.For the shelves, I cut some 2 1/2" long pieces of 1/4" rod.  Drilled thru the side tubes, welded flush on the outside leaving 1/2" sticking thru on the inside.  No visable weld after polishing and the shelf rests on those pegsAnd some weld shots
Reply:Nicely done!  Thumbs up man Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Nice job and nice fit up. If you don't mind me asking, how much do you charge to put one of those table frames together? The reason why I ask is because I do little projects like those and I have a hard time pricing it out. I'm trying to rule out if people I'm Miami are cheap or am I over charging. Thanks
Reply:JRwldrDo you have any closer photos of the pin, and corner areas after dressing.Opus
Reply:Aw crap. Put it on the list of things I want now! I love that design! Great work and the welds look awesome.How much of a pain was it to not get the bottom to warp at all being that it was stainless? And what angle did you cut the legs on?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Nice work!  I think in the right setting, that design could look really cool.Jack OlsenMy garage website
Reply:Those things are clever and beautiful! Will we get to see them "topped"? Would also like a detailed shot of the little feet thingies..(if that's what they are). Man, lining up and/or jigging up everything perfect on those suckers during assembly would have to be a challenge. Nice job!!!  POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:Nice design..... And good looking welds........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Freakin awsome bud! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Great work!-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:@ JRweldr - Your 'Z-Rock' SS Tables are pro!  Sweet design lines and beautiful weld geometry."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Thanks fellas for the compliments.  These tables are definitely a love it or hate it design.  The guy these are built for is Italian with some sort of architectural background.  Never met the guy personally, but I have heard that he absolutely hates curves.  These were all welded on a Dynasty 300, 1/16 tungsten and filler, 120amps at the machine, no pulse.  All freehand welding using weld sequence and weld pull along with a slab a granite to check for flatness.  No fixtures of any kind for this jobThe legs are cut at 37.5°Here is an inside shot of the pin.  I'll try and get a shot of the corners tomorrow if I can rememberAlso, those little things on the top are keepers for a thick glass top or glass display case.  Just some scrap tube, cut into 4 pieces length wise.  Similar to angle ironLast edited by JRwldr; 07-09-2013 at 07:31 PM.
Reply:Man..... I wish I could read the whole post.........If you can resize your images or take slightly lower Rez shots it will work better.......You clearly are good at what you do and I hate missing words on good posts.......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:I'll see what I can do to fix it.  Its only on this forum that it happens for some reason
Reply:In the mean time to read the missing text, you can choose show printable version under the threads tools tab at the top of the thread. It will show the text and a url to the pictures. mooseTimmetalcraft by mooseSoutheast Michiganhttps://www.facebook.com/Metalcraftbymoose  Stupid Hurts!!
Reply:I tried to fix it.  Photobucket app has no resize options.  And the photobucket site won't let me.  Any other ideas
Reply:Same here.....Stainless is my current fave.....How did you finish?Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:JRwldrKudos aside: what size filler rod did you use for the inside [corner], and outside welds.Opus
Reply:Nice tables, nice welding.  Super looking welds.Hey~!! It's a hobby. It's not supposed to make sense~!!
Reply:Quoted and took out the image.  Should be able  to read it all now...   Originally Posted by JRwldrThanks fellas for the compliments.  These tables are definitely a love it or hate it design.  The guy these are built for is Italian with some sort of architectural background.  Never met the guy personally, but I have heard that he absolutely hates curves.  These were all welded on a Dynasty 300, 1/16 tungsten and filler, 120amps at the machine, no pulse.  All freehand welding using weld sequence and weld pull along with a slab a granite to check for flatness.  No fixtures of any kind for this jobThe legs are cut at 37.5°Here is an inside shot of the pin.  I'll try and get a shot of the corners tomorrow if I can rememberAlso, those little things on the top are keepers for a thick glass top or glass display case.  Just some scrap tube, cut into 4 pieces length wise.  Similar to angle iron
Reply:Phenomenal! That is a very clean work. I like the design and your attention to details.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Cool and great looking tables! Like the geometric design with all those angles, great modern and sleek look. Great job!
Reply:Great design and beautiful craftmanship.HH 187Lincoln 225ACEverlast 160ST
Reply:Very Nice!!!!!Miller Big Blue Air PakMiller 350P, Python GunHyperthermsSpool gunsMetabo GrindersWe "dooit" as a family...."a family that sleds together stays together"......from sleddin to campin to 4 wheelin to workin.....gotta enjoy life somewhere!
Reply:thay look so sweet!!
GMT+8, 2025-12-29 09:21 , Processed in 0.074286 second(s), 18 queries .
