How am I doin' boss? (novice tig)
发表于 2021-8-31 22:49:29 | 显示全部楼层 |阅读模式
The corner goes from open to closed about 3/8" from the right. 130a, 3/32" gold, small gas lens, lincoln pt375, 20 torch. Attached ImagesSqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:I like it.  What are you making?Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:They never tell me. It's just a bracket, 40 parts, 4 corner welds each, and on to the next...SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:What's the rebar thingamabob? Looks nifty.Bruce
Reply:Originally Posted by Bruce AvisonWhat's the rebar thingamabob? Looks nifty.Bruce
Reply:Yup, the third hand is way quicker than clamping the part upright, provides a good ground, thanks to Jody and the forum for the idea.SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:Did you weld a little contact pad on it to prevent little black marks too?I had to cause it was still arcing off my tip sometimes.  I used a piece of copper house wire for the tig rod.     (also Jody's idea)Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Good plan, I took 8" of 14 ga copper wire in and added a little contact bead to the point, feet and every 1" on the arm, much better.SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:1 Canadian peso for scale. Attached ImagesSqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:Lots of open corners. Attached ImagesSqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:I hate dirty metal. 5052 with 5356 filler, clear anodized.Grease halos on SS after alcohol wipe. Attached ImagesSqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:Nice work!
Reply:That third hand is the balls Gawd, I love this forum...POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:I'm loving my new 3rd hand, made out of 316 SS rebar from a local bridge project. Here's my best weld this week. Attached ImagesSqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:Brazin   -   Color MatchingThe aluminum anodized corner is especially interesting because it offers three design opportunities.1)     Weld it, anodize, and install.2)     Color match the filler and parent metal so  the                  weld doesn't show [make your own filler rods].3)     And the best: for the Arts and Crafts welder that wants to develop an effect or technique.  Mismatched filler, then anodized, produces a look very much like graphite-drip drawing, on water color paper.This is how you get that effect with metal.One of you creating guys  -  take this and run.Opus
GMT+8, 2025-12-29 09:10 , Processed in 0.136392 second(s), 18 queries .
