First Project 4" Cowl Hood K5 Blazer
发表于 2021-8-31 22:49:27 | 显示全部楼层 |阅读模式
I have since sold this truck but thought I would show my first project.Everything was TIG welded. Attached Images
Reply:and here is 5 more Attached Images
Reply:here is 5 more Attached Images
Reply:5 more Attached Images
Reply:and again Attached Images
Reply:didnt realize i took so many pics Attached Images
Reply:here we go Attached Images
Reply:almost done Attached Images
Reply:i'll have to look and see if i have any of it on the truck before i sold it. Attached Images
Reply:I know I know the tires are way too small for that truck. just didnt ever put more money into it! Attached Images
Reply:did you relocate the hinges or did you keep them in the same spot?
Reply:Originally Posted by Virginiadid you relocate the hinges or did you keep them in the same spot?
Reply:Nice job on the hood. You did good at controlling the heat(preventing warpage) on those large flat panels. Is that your welding school shop ? Looks nicely equipped.
Reply:I think the concern was the cowl impacting the windshield when the hood was up.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Both were major concernsYes, that was wyotech. Been out of the game for a couple years but plan on getting into it heavy shortly.The 3/8" bar that ran across the top of the back of the cowl and down to the base of the hood was so that the cowl would not bounce or vibrate when driving at freeway speeds. or if someone pushed on it. With the bar welded in you could almost stand on the back lip.Thanks guys!
Reply:Nice job!!!
Reply:Originally Posted by RMWNice job!!!
Reply:Turned out really nice, Kalvin. I like how other than the sides and the support you retained everything from the original hood.Miller XMT-3502 Lincoln Power Mig 140C (One w/ dedicated spoolgun)Jackson NexGen / Miller Digital EliteMiller S32P SuperWeldcraft 17fv & 9fv Tig TorchVictor & Purox O/ALincoln Ranger 9Fairly Cold Beer!!
Reply:Thanks! Yeah I really didnt want to pay $800 for a all steel cowl hood, and Fiberglass just seemed a little blah for that truck. So I spent $90 and made my own!! I've seen some pretty horrible ones on google images but theres a few nice ones too.
Reply:That turned out really well. Very clean work!PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Thanks! feel free to give pointers. May do another one on my new truck.HF Special MigReally Old Miller StickMy 4" Cowl Hood Build(pic heavy)
GMT+8, 2025-12-29 12:48 , Processed in 0.131715 second(s), 18 queries .
