Fire pit logs
发表于 2021-8-31 22:49:21 | 显示全部楼层 |阅读模式
Has anybody been asked to make steel fire pit logs? Similar to these. i could use some tips on how long it would take to build them and materials. Thanks,TroyLincoln 175Monkey Wards 230v.  Stick
Reply:That's cool and I never anything like that, You could probably make it all from scrap! No need to get structural or buy a super expensive machine to build that Depending on the design it shouldn't be more than a couple hours to build something similar.
Reply:One of the metal shop teachers here had students do "wood" logs out of steel a while back. I can't remember what member it was at the moment though.Found it.http://weldingweb.com/vbb/showthread.php...-HS-Shop-Class.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thanks DSW!Lincoln 175Monkey Wards 230v.  Stick
GMT+8, 2025-12-29 09:10 , Processed in 0.108155 second(s), 18 queries .
