ring roller and brake
发表于 2021-8-31 22:49:18 | 显示全部楼层 |阅读模式
just bought a small ring roller bends up to 3/16 x 1" and 1/4" roundfrom HF same as woodward fab but only $64.99 not $89.99also the HF 36" brake on sale for $179.99 i saw on here a long time a go some one beefed it up with some 2" channel Attached Images
Reply:I have the red brake also. Perfect for autobody sheetmetal...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:i think the up grade was under pirate 4x4 .com 36" brake mod.anyone have it
Reply:I don't know where the mod was at, but this is the only board I go to and I saw it on here. I bought one of their benders and never have set it up. They were out of the ring roller. I think it would be real handy for some of the ideas I have in mind.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:Suggestion on the roller.  Disassemble, clean and flush out crud/grit, lube and reassemble.  It works much more smoothly then.IIRC, to beef up the brake just look at the back of the existing angle iron and put an 'opposing' angle behind it to turn the angle iron into a box beam.  The best laid schemes ... Gang oft agley ...
Reply:I think the brake is made to cheap to do much beefing. The pins on the folder are only like 5/8" and i think that will be the first place it breaks. just my .02...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
GMT+8, 2025-12-29 09:20 , Processed in 0.095531 second(s), 18 queries .
