Bending/ring roller Q
发表于 2021-8-31 22:49:18 | 显示全部楼层 |阅读模式
I need something to make bends - from 60 to 180 to 360+ (kinda like a coil) in 1/8 stainless wire (if can do thicker, great) with radius from 1" to 5-6"... I need something like this ring roller: http://www.harborfreight.com/cpi/cta...emnumber=36790  - but it only makes rings of 3" radius and higher...  Is anyone aware of ring rollers that can make smaller radius rings?
Reply:http://www.northerntool.com/webapp/w...2574_200012574I didn't see a minimal radius on this one.http://www.metalcraftusa.com/rivet.htmlI don't know how many you have to do.  However If you have many individual rings to roll then you will have much drop.I would suggest heating and rolling a continuous coil around an appropriate sized drop then cutting the parts from the coil. That might be what you intend to do "(kinda like a coil)".Also, I am sure somebody sell ready-made rings.  Springs might work for you.Just some suggestions.
Reply:Thanks, didn't see those on my searches.I do RBS (rolling ball sculptures) - it's a hobby. Here is an [ame="http://video.google.com/videoplay?docid=8687338146090746261&hl=en"]example[/ame]....As you can see, I need fairly precise curves. The stuff that makes only certain diameter curves won't do, I need variable diameters. Currently I do this stuff by hand, just bending wire around various diameter PVC pipe pieces, but I wish there was a more precise method..That 2nd link seems good but pricy  I checked further into the HF ring roller, and I see a place that says you can make 1" rings with it... Maybe I will try it.By the way, the coil part would be for an "archimedes screw"-like ball lift.
Reply:I have the HF Ring Roller and for what you want to do the Northern bender seems like a better fit.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-29 09:09 , Processed in 0.110651 second(s), 18 queries .
