查看: 13|回复: 0
Recipitating Saws...
发表于 2021-8-31 22:49:18 | 显示全部楼层 |阅读模式
Just got a new saw..So far it's the best one I've ever had in my hands...Anyone else try one of these??I really like this "Quick Change Blade Holder"..I stripped the ring gear on the last saw I had so I got this..Far and away the most power and less vibration saw that I have used..If you need a saw like this I suggest this one.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice looking saw. I have used sawzalls before and they are awesome. My local home depot has a Ridgid brand on clearance for 49 bucks but I am not sure of the amp rating. I am about to go up there to buy some bolts and will have to take a double look and maybe buy the thing.So do you think 8.5 amps is plenty to get the job done? I have seen some that are even 13 amp and I always wondered what would be enough.
Reply:Originally Posted by 737mechanicNice looking saw. So do you think 8.5 amps is plenty to get the job done? I have seen some that are even 13 amp and I always wondered what would be enough.
Reply:Yep, I use mine all the time.  I have a 15 year old Milwaukee.  Still runs as strong as the day I got it.  I bet that quick change blade holder is nice.  Changing mine with an allen wrench gets old fast.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:I've got several. My makita is the lightest and has a std blade clamp. I have 2 Porter Cables one with and one without the quick change blade. I dislike the PC quick change blade clamp as the blade moves around too much for my taste and precision work. It is great on things like demo where I break a lot of  blades however. That design looks better on your saw.
Reply:Originally Posted by Hammack_Welding I bet that quick change blade holder is nice.  Changing mine with an allen wrench gets old fast.
Reply:Oh good grief....List for tomorrow1.  go to dump2.  eat hot wings and read the news paper for brunch3.  go Lowes and  buy a saws all cause it makes too much sense. weld it like you own it
Reply:Milwaukee, the origial "sawzall" has a twist to release blade change, works awsome. But expensive. Looks like that will do the job easy enough. Can probably buy a couple of those for one Milwaukee.Tim Beeker.
Reply:Originally Posted by tnjindMilwaukee, the origial "sawzall" has a twist to release blade change, works awsome. But expensive. Looks like that will do the job easy enough. Can probably buy a couple of those for one Milwaukee.
Reply:i have a milwaukee too, its awesome.  Im waiting for my 28 volt one to get here, ive used my uncles though and it has plenty of power.
Reply:I've got SKIL brand also but the older model without the quick change feature.But other than that My buddy and I have cut alot different stuff with it.A real work saver sometimes.You'll love that one zap.pro-level dumpster diver                                     Hobart 125EZ
Reply:The B&D saw has the same quick release blade mechanism.  Regular cost is about $80.  If I found one at the price you did, I'd own one now too.
Reply:Have you never used a Milwaukee Sawzall?  They will put up with the whatever abuse you can find for them and have power to spare.  Just don't use one with a hangover; bind up a blade and it will scramble your brains.  Milwaukee has always had the best speed control with their triggers.However, the quality of blade you use is what really makes all of the difference.Last edited by 76GMC1500; 07-23-2008 at 02:03 AM.
Reply:I work with pipefitters and plumbers 90%/10% respectively. We have been using the Milwaukee brand of recipricating saw. Inside of 4-5 months I have seen the guards which slide back and forth and are located around and below the blade get bent and break off of 4 to 5 of these saws. I think the metal is way to weak for what is being asked of it.The blade release is the rotating type. These tend to get stuck when heated up or have lots of dust on them. I have used the long lever release type and prefer them to the rotating type...so far.Which brand of sawzaw and blade stands up to tough stuff best?Blades:We have been cutting risers out and these consist of 1-2.5" galvanized pipes along with black pipe at 1" diameter. I am disappointed with the blade life feeling that on average I'm only getting about six cuts before the blades are toasted. We have been using Lenox 10's, 14's, and fine blades. I know to go somewhat slow as the blades are more aggressive in size...Normal for blades to die so soon? HAPPY WELDING UALL
Reply:Originally Posted by drivethruboy54i have a milwaukee too, its awesome.  Im waiting for my 28 volt one to get here, ive used my uncles though and it has plenty of power.
Reply:Originally Posted by 737mechanicNice looking saw. I have used sawzalls before and they are awesome. My local home depot has a Ridgid brand on clearance for 49 bucks but I am not sure of the amp rating. I am about to go up there to buy some bolts and will have to take a double look and maybe buy the thing.So do you think 8.5 amps is plenty to get the job done? I have seen some that are even 13 amp and I always wondered what would be enough.
Reply:Can you please tell me what is canning wax i am from the united kingdom and not heard this expression before, thanks
Reply:Originally Posted by coldlapCan you please tell me what is canning wax i am from the united kingdom and not heard this expression before, thanks
Reply:My blades smell like "mornin sunshine"    because I use a big fat scented candle  weld it like you own it
Reply:canning wax = plain wax used to make home-made candles or to seal home canned/jarred goodsIIRC, in the UK 'paraffin' refers to something different than what we think of in the US.  UK 'paraffin' is what we call kerosene.As mentioned, you could just use a plain wax candle (or candle stub).  Fancy scents optional.  The best laid schemes ... Gang oft agley ...
Reply:I've got to say that this is the first time I've ever heard of a "Skil" tool recommended for a "production shop".  In my estimation, the Skil brand (overall) is targeted at the home hobbiest, not the guy who uses his tools for his livelihood.Thirty years ago a Skilsaw was the cat's meow.  They pretty much owned the market.  That is no longer the case.  They have become a "consumer tool manufacturer" rather than an industrial supplier.  Pretty much the same with Black & Decker.Over the years I've used sawsalls from B&D, Milwaukee, Dewalt, Makita, Bosch, etc.  The Milwaukee's seem to be the "most heavy duty" and the Makita's the smoothest operating.  The Dewalt's tend to run too hot to suit me.I do have one "cheap" 7 1/4" Skilsaw in the shop which has a Morse thin metal cutting blade installed.  I use it for sheet metal so as not to "screw up" the Milwaukee Metal Cutting Saw.  I look at it ($49 or so) as a throwaway when it goes bad.  That's the only "Skil" tool I own.  PS.  I generally don't buy my tools at Wal-Mart.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Dewalt has become a "disposable tool" manufacturer too.  We beat the hell out of the milwaukee portabands and they hold up a very long time.  We had a brand new dewalt and it didn't last a month, that makes the second dewalt portaband we've toasted.  I can't even remember how many of the junky dewalt grinders we've been through.  Bosch grinders have held up the best so far.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:A little off the topic perhaps but bee's wax is great for tapping SS.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by SundownIIII've got to say that this is the first time I've ever heard of a "Skil" tool recommended for a "production shop".  In my estimation, the Skil brand (overall) is targeted at the home hobbiest, not the guy who uses his tools for his livelihood.Thirty years ago a Skilsaw was the cat's meow.  They pretty much owned the market.  That is no longer the case.  They have become a "consumer tool manufacturer" rather than an industrial supplier.  Pretty much the same with Black & Decker.Over the years I've used sawsalls from B&D, Milwaukee, Dewalt, Makita, Bosch, etc.  The Milwaukee's seem to be the "most heavy duty" and the Makita's the smoothest operating.  The Dewalt's tend to run too hot to suit me.I do have one "cheap" 7 1/4" Skilsaw in the shop which has a Morse thin metal cutting blade installed.  I use it for sheet metal so as not to "screw up" the Milwaukee Metal Cutting Saw.  I look at it ($49 or so) as a throwaway when it goes bad.  That's the only "Skil" tool I own.  PS.  I generally don't buy my tools at Wal-Mart.Originally Posted by DSWMy only Skilsaws are  my worm drives, I've got 3 different ones, 7 1/4", 8 1/2" and one with a 10" aftermarket blade and guard. Now almost everyone has a worm drive they offer. Bosch seems to be the best from what I have heard, but the old Skil's still rank right up there. I have killed a few but they lasted way longer than anything else under the abuse we put them thru.
Reply:i just picked this one up today. 12a motor. this think is violent! it rippes through 14g to 3/8 steel with no problem. ive always used wd40 or somthing similar. would the wax be a better idea? Attached ImagesLast edited by kmaysob; 07-30-2008 at 12:21 AM.Millermatic 211weldpack 3200 squirtgunsquare wave 200victory journeyman kitHypertherm 30xptoo much other crap to listtinkerer extraordinaire
Reply:Originally Posted by tanglediverHow many times have you picked up a wormdrive Skilsaw that the whole crew uses, only to find the base plate twisted beyond all comprehension?  NOBODY touches my wormdrive Skilsaw, nobody!!  I remind myself of Daffy Duck, "Mine, mine, mine, down, down, down, go, go, go!" Never leave home without the sawzall, (n)either!!
Reply:Originally Posted by duaneb55A little off the topic perhaps but bee's wax is great for tapping SS.
Reply:Originally Posted by zapsterHow long does the Battery last??...zap!
Reply:Originally Posted by MoonRisecanning wax = plain wax used to make home-made candles or to seal home canned/jarred goodsIIRC, in the UK 'paraffin' refers to something different than what we think of in the US.  UK 'paraffin' is what we call kerosene.As mentioned, you could just use a plain wax candle (or candle stub).  Fancy scents optional.
GMT+8, 2025-12-29 11:03 , Processed in 0.112914 second(s), 18 queries .
