compressor today
发表于 2021-8-31 22:49:18 | 显示全部楼层 |阅读模式
showed up today Attached Images
Reply:I've got one just like it . Works well . Before you take it off the pallet , be sure to replace the factory drain valve with a 90 degree elbow , 6"( or longer ) extension and a small ball valve .This will make draining the tank super easy . It's all but impossible with the factory setup .
GMT+8, 2025-12-29 09:20 , Processed in 0.102502 second(s), 18 queries .
