T/A 186 Tig Torch parts
发表于 2021-8-31 22:49:14 | 显示全部楼层 |阅读模式
Are the parts for any 26 series torch inter-changable with any make of torch? ie, CK in a Weldcraft, Weldcraft in a Thermal Arc and so on and so on......
Reply:unless it's some kind of specialty 26 torch, all parts should interchange so long as the torch manufacturer designates it as a "standard" 26 torch.  The threads should all be the same.What kinda parts are you looking at?  cups/nozzles/collets/collet bodies? 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Mainly cups (the ones that came w/ the torch have some smudge on them from me being a rookie), was looking at one of them gas saver things also......
Reply:I know the stuff from my wp17 v. Fit my ta 26Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:The 186 is a gas cooled torch, so it takes "3 series" consumables. All the cups, collets, collet body etc should be on the shelf at your LWS and they are relatively inexpensive.The gas saver series is nice if you're really using the torch a ton. They run in the high 20's to 40 bucks or so. One thing to keep in mind, however, is that the Pyrex cups that equip the gas saver only come in size 8 (or so I believe).www.triarc.us
GMT+8, 2025-12-29 11:14 , Processed in 0.095933 second(s), 18 queries .
