spoolgun
发表于 2021-8-31 22:49:12 | 显示全部楼层 |阅读模式
I have a millermatic 210 im looking at buying a spoolmatic15A to run on this machine has anyone run this combo looking for some input, will it work does it work good ,thanks John
Reply:My MM210 uses the Spoolmate 3035.  Got it used, direct plug and play.I would like to be able to control wire speed at the gun end like the 15A model though - too spendy for meDave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:A 15 or 30A will work on a MM210 by using a 195287 adapter cord and adjusting wire feed speed at the machine.
Reply:My mm210 has a 4 pin hook up and the spoolgun does tech man says it will work so I guess im gonna order Monday. Thanks for input.
GMT+8, 2025-12-29 09:21 , Processed in 0.071283 second(s), 18 queries .
