how has welder parts
发表于 2021-8-31 22:49:10 | 显示全部楼层 |阅读模式
If any one has any SA 200 Short hood F162 parts and wanting or willing to sell  let me know. Or maybe know where I might be able to purchase parts. i'm trying to get mine going again. Thank You TomPit9
Reply:I'm looking for a starter for a 1955 short hood Lincoln SA200 f162.
Reply:what kind of parts are you needing? several machines in my area? restoring a 48 now myself
Reply:call 405-238-6421, James Supply in Duncan okla. thought I had one but it does'nt fit my shorthood
Reply:Thanks I'll give them a call
Reply:I was told by phone yesterday that Stumpf had around 250 parts machines, he should be able to hook you up with a started
Reply:Is this the James Supply in Duncan, OK.
Reply:no its in Ill.
Reply:Make sure that starter will not fit the short hood. We have used the Delco 1107382 - the shaved side starter - for years on the s models. In many cases, it is necessary to put a slight bend in the lifting bale, assuming yours has this piece of formed gauge metal as opposed to the 5/16" thick solid steel that was used in the early 40's. You can easily do this with a pair of vice grips. Some units also required a 3/16" spacer under starter, but this starter has the guts to crank engine on coldest day.     James supply is in Pauls Valley, Ok and Stumpf is in Mascoutah, Il, just outside St. Louis.
Reply:im looking for the radiator cap cover or guard on a lincoln sa 200. please let me know where to get one.  im also looking for the current dials.  like a bullet or something diffrent.   thank you
Reply:i have several parts machines for short hoods and long hoods.i also manufacture new hoods and doors for sa 200's too.
Reply:i have one if you need [email protected]
Reply:Originally Posted by tompit9I'm looking for a starter for a 1955 short hood Lincoln SA200 f162.
Reply:What is the damage on the top ear?
Reply:Originally Posted by tompit9What is the damage on the top ear?
Reply:james supply is in pauls valley  oklahoma. Highway 60 equipment has alot of parts tooo. i have 3 shorthoods for parts. [email protected]
Reply:looking for a starter for a 54 shorthood     [email protected]
Reply:i can get the ac delco starters shaved on 3 side for you guys but they are'nt cheap and i'm in texas 150.00 plus shipping and i'll need a core sent back to me or there's and extra core charge of 30.00Shad
Reply:Originally Posted by rafter g weldingi can get the ac delco starters shaved on 3 side for you guys but they are'nt cheap and i'm in texas 150.00 plus shipping and i'll need a core sent back to me or there's and extra core charge of 30.00
Reply:not sure of the part number but yes they are delco starters shaved on 3 sides not sure if they are standard equipment but think they were added on after buying a new unitShad
Reply:i have a long nose starter 75.00 plus shippingShad
Reply:do you still have that starter and does it work? the one I picked up is stuck in the out pos. and don't know whats wrong with it.
GMT+8, 2025-12-29 09:20 , Processed in 0.073605 second(s), 18 queries .
