Not quite a Shepard's hook...
发表于 2021-8-31 22:49:04 | 显示全部楼层 |阅读模式
so i will call it a garden hanger.Made a couple of these by request on Saturday. Attached ImagesECAVE Still learnin'Lincoln AC225Lincoln 135SPHF ChopsawVictor O/ANumerous other items
Reply:so sweet! did you make the tip/point also?
Reply:Originally Posted by Virginiaso sweet! did you make the tip/point also?
Reply:cool.  I like the design
Reply:Great jobWhat is the center bar? Please provide details!!!!Dave ReberWadsworth Ohio
Reply:Originally Posted by Scott Youngcool.  I like the design
Reply:Originally Posted by ReebsGreat jobWhat is the center bar? Please provide details!!!!
Reply:Nice. Do you have anything on the bottom of the pipe for going into the ground for stability ? I made something similar and welded four flat stock pieces to the sides at the bottom. Mine were some left over triangle cutouts. I quarter the pipe and welded them on. It gives you something to pound on if ground is hard.
Reply:Originally Posted by BD1Nice. Do you have anything on the bottom of the pipe for going into the ground for stability ? I made something similar and welded four flat stock pieces to the sides at the bottom. Mine were some left over triangle cutouts. I quarter the pipe and welded them on. It gives you something to pound on if ground is hard.
Reply:Thanks They have a craft type show where I teach before x-mass. I want to make something cheap that will sell. I hate to make a bunch with no knowledge if they will sell. I prefer to make a few and take orders for the rest but I don't think that is the best method at a craft sale.Dave ReberWadsworth Ohio
Reply:Great work, I like the design. It makes a great addition to the garden.
Reply:Thanks Ironman50.ECAVE Still learnin'Lincoln AC225Lincoln 135SPHF ChopsawVictor O/ANumerous other items
Reply:Did you purposely invert the position of the vertical scrolls from one hanger to the next? Just curious and trying to decide which way I like better.
Reply:Originally Posted by ranger_5_0Did you purposely invert the position of the vertical scrolls from one hanger to the next? Just curious and trying to decide which way I like better.
GMT+8, 2025-12-29 09:20 , Processed in 0.099043 second(s), 18 queries .
