Adjustable trailer tounge
发表于 2021-8-31 22:49:02 | 显示全部楼层 |阅读模式
Stopped by the farm store to today and this beauty was sitting right up front. That there is quite the invention! Also liked the missing front wheels.
Reply:is it sad that i actually said "i have seen worse"?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Is that thing made of an old corral gate and some angle iron?
Reply:Now that's a thing of beauty. Warms my heart to see such exceptional fabrication skills.1981 SA-250 D3.1521985 Cab & Chassis Chevy C30
Reply:That's the ultimate in farmer fabrication right there. Sent from my DROID RAZR using Tapatalk 2Hobart Stick mate LX AC/DCHarris O/A outfit
Reply:Prime example of why so many people on here freak out about trailer builds... "Don't worry, it's just for use around the property.".... My a$$.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by celticroots That there is quite the invention! Also liked the missing front wheels.
Reply:If you look at the left edge of the pic you see a hub with no wheel on it, above it you can just barely see the drivers side rear axle tire.
Reply:at least it's empty...There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by ThorsHammerat least it's empty...
Reply:Looks like some had a bunch of pipe layin around.. too. That is an ugly POS. And yes I have built my own trailer.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:It's always been said that the drugs we took in the sixties would come back to haunt us in our later years. That thing is living proof. You just gotta love it....POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:Originally Posted by celticrootsIf you look at the left edge of the pic you see a hub with no wheel on it, above it you can just barely see the drivers side rear axle tire.
Reply:Some real creativity there I must say---No good deed goes unpunished---
Reply:I kind of like it --------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:hey lookie, that there trailer gots its hemorrhoids on ta front. hot dayum, now I have seen it all........ Last edited by allfluxedup; 07-19-2013 at 08:43 PM.Reason: silly emoticon trips r 4 kids
Reply:notice the fine job mounting the tongue jack,,,,,,,thou shalt spareth no expense      hahahahaahaha
Reply:I wish we had pics of rest of the trailer.Qualified & experienced at welding scrap metal
Reply:You guys are so CRITICAL!Look CLOSER!It has 2 (YES, TWO!) SAFETY CHAINS!HEE! HEE!PSI give him credit for Resourcefulness and Ingenuity!
Reply:I won't argue it could be better, but I like the setup on the tounge so long as it's built strong enough kind a cool idea.
Reply:Youd think that someone who drives a $40,000+ plus truck could afford a couple grand for a decent trailer...[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Originally Posted by LanseYoud think that someone who drives a $40,000+ plus truck could afford a couple grand for a decent trailer...
Reply:Probably sings like a pipe organ going down the road, should play the Funeral March.Big Time POS!"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Actually, it just looks like a repurposed pipe structure of some kind.  Or, if it was built as a trailer, that's some pretty accurate pipe fabrication.  The radius bending, and fitup, is excellent looking from here.The "hub" doesn't appear to be a hub though.  No studs for wheel mounting.  And I don't see holes for ag type lug nuts unless the nuts were broken off flush on the original structure.  Either way it was never meant to be an actual working hub on the "new" trailer I believe.The tongue is interesting.  Can't say as it's any weaker than most commercial built trailers.  It's not adjustable BTW.  The hitch is solid welded.  I especially like how the dood tapered the connection between pipe and hitch (Bulldog.....a nice choice....the best out there)Really guys, it's pretty neat in a sorta Americana way.  Shows there's different ways to skin a cat  Just cause it's different doesn't make it bad."Any day above ground is a good day"http://www.farmersamm.com/What FARMERSAMM says, "Really guys, it's pretty neat in a sorta Americana way. Shows there's different ways to skin a cat Just cause it's different doesn't make it bad."I agree, sure its OK to joke about it but remember you guys are not ALL Structural Trailer Design Engineers.......
Reply:Boy howdy. I make it to that store a couple times a month...  So far I've been lucky and avoided such stupidity.
Reply:I need one of those---when my friends, family, and neighbors come over to borrow a trailer---------
GMT+8, 2025-12-29 12:48 , Processed in 0.227684 second(s), 18 queries .
