查看: 2|回复: 0
Tig Cooler
发表于 2021-8-31 22:49:01 | 显示全部楼层 |阅读模式
Here are some pics of the Tig cooler i built.And here is the pressure regulator, flow meter and pressure gauge that sit on top of the welderI still have to get a PID controller, fan and build a case around the unit.
Reply:The attached image show where you should adjust the pressure on your system. There is a spring loaded by-pass under there to adjust the pump's output.And the regulator you are using looks like an air type?? Attached ImagesLast edited by acourtjester; 07-30-2013 at 08:42 AM.Reason: add info
Reply:Originally Posted by acourtjesterThe attached image show where you should adjust the pressure on your system. There is a spring loaded by-pass under there to adjust the pump's output.And the regulator you are using looks like an air type??
GMT+8, 2025-12-29 09:20 , Processed in 0.072189 second(s), 18 queries .
