oxyfuel cart
发表于 2021-8-31 22:49:01 | 显示全部楼层 |阅读模式
i'm gonna be making a cart for my oxygen and acetylene tanks i'm using 1x1 square tubethe square tube is 1/8 inch thick i'm gonna stick weld everything on the cart i'm gonna use 6013 rods for this is 6013 the best rod i could use ?
Reply:Nothing wrong with 6013 for this application.  Use a 3/32" rod and have at it My chart lists 3/32" 6013 rods at 40-90 amps.  Experiment on scrap until you are dialed in first, even if it takes an hour.An 1/8" rod on 1/8" metal is harder to do if you don't have a lot of experience - it works, just harder.Dave J.Last edited by MinnesotaDave; 07-30-2013 at 12:54 AM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Yep, what Dave said...I'm interested to see your design as I need to build one too...GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Looking for a good design as well
GMT+8, 2025-12-29 13:02 , Processed in 0.115258 second(s), 18 queries .
