M4017 silicon relay steel needed
发表于 2021-8-31 22:48:58 | 显示全部楼层 |阅读模式
Alright welding gurus as usual i come to you for answers when I am at the end if the rope. Ok I need some of this steel to manufacture a sleeve for a shaft it has to be this steel as it is part of a torque feed back system. Any help would be great. Ludlum relay steel #5 M4017 silicon steelLycoming raw material p6600-201Thanks in advance  CheersUsing Tapatalk
Reply:Any. advice pleaseUsing Tapatalk
Reply:.....and let's see---you cannot or will not do any google, etc. searching (which shows relevant hits) on your owntime & dime, nor contact any distributors, and will not provide the size and quantity of material needed.Blackbird
Reply:what size part ?  and how much TQ feed back are we talking about?
Reply:Originally Posted by dave powelson.....and let's see---you cannot or will not do any google, etc. searching (which shows relevant hits) on your owntime & dime, nor contact any distributors, and will not provide the size and quantity of material needed.
Reply:Originally Posted by Bigrich954rrwhat size part ?  and how much TQ feed back are we talking about?
Reply:http://lmgtfy.com/?q=Ludlum+relay+steel+%235+
Reply:Originally Posted by Insaneridehttp://lmgtfy.com/?q=Ludlum+relay+steel+%235+
Reply:So I guess its wait until we buy a couple hundred pounds if it Using Tapatalk
Reply:These guys make it  https://www.atimetals.com/Pages/default.aspxFor bar stock it says to call 800-841-5491  Ask for the #5 relay steel.
GMT+8, 2025-12-29 13:04 , Processed in 0.126222 second(s), 18 queries .
