Need recomendations for suppliers
发表于 2021-8-31 22:48:55 | 显示全部楼层 |阅读模式
Hello all, I'm having trouble finding good sources for water traps/seperators. Automatic empty would be even better. Thanks in advance Brian
Reply:Where are you located?? It would help tremendously if you were to post your location.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:http://www.mcmaster.com/Punch in catalog page 940, or 945 for the really big industrial units.  Lots of choices, some with auto drain.WeldingWeb forum--now more sophomoric banter than anything else!
Reply:Grainger http://www.grainger.com/Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
GMT+8, 2025-12-29 14:57 , Processed in 0.078061 second(s), 18 queries .
