Changing from Co2 to C25
发表于 2021-8-31 22:48:52 | 显示全部楼层 |阅读模式
I bought co2 for my mig steel when i purchased my MM210. After learning of C25 for steel, I want to exchange bottles. Do I need to change or modify my co2 regulator for this mix?OzDynasty 200DXMiller 210 Spooly
Reply:Usually the standard reg that comes with that machine is set up to run C25. You have to add an adapter to the reg to use it with 100% CO2. If for some reason you have a reg set up for straight CO2 as opposed to one with an adapter, you may have to either get an adapter or get a reg with the correct CGA fitting..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thanks DSW, ill check that out. Seems like I saw an adapter of some sort when i got the machine a few years ago.OzDynasty 200DXMiller 210 Spooly
Reply:What will c25 do for u that co2 does not
Reply:100% Co2 gives you a slightly hotter weld and a bit more penetration, but you get more spatter as well. 100% isn't the best choice for say doing sheet metal body panels where you want less penetration. C25 would be the better of the two for that,.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Co2 will give you much more weld time because it's a liquid. C25 is a gas and it doesn't last as long as CO2. Where I live the CO2 is half the cost of C25.Just somethings to think about.
Reply:I just want less spatter. Less clean up. Im just a hobby welder anyway. So I like the welds I do produce, to look nice and neat. I tig everything thats practical, but sometimes its just too much for the amount of time I have to dedicate.OzDynasty 200DXMiller 210 Spooly
GMT+8, 2025-12-29 13:02 , Processed in 0.104872 second(s), 18 queries .
