fired up my TA 211i
发表于 2021-8-31 22:48:51 | 显示全部楼层 |阅读模式
for the first time. First time I'd  welded anything  since my one time in the 1980s welding some plate with a big old stick machine. Once I got the power set right ( 55 - 56 amps)  it stick welded beautifully,  no stuck stick, no blow through,  it's a crappy picture but it's my first weld  woo hooNow I gotta find me some gas and try my hand at MIG and  GTAW. I purchased the pedal with this Lift-TIG box which should make things easier. Consummables were Lincoln - Fleetweld 180 Premium Stick Electrode E6011 3/32 Anyway here's the proof. Hey~!! It's a hobby. It's not supposed to make sense~!!
Reply:Nicely done!Your machine is awesome.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:That 252i has a beefy duty cycle (40%) for not a lot of money.  I might have gone for that machine but for the fact that  the 20% on the 211 is for 210 amps and unless I'm welding heavy stuff I won't be at that power output. For most of what I'll likely be welding the Duty Cycle will  70% or even 100% with amp load between 50 and 120.    I just emailed TA to complain about the work clamp  and demand that they send me  the one that the literature describes and also shows a photograph of.  P 3 of the brochure. They have had this issue since at least the beginning of the Fabricator line. I can't believe they just leave the brochure as it is without changing it.   Maybe  almost nobody complains and they have a boat load of the brochures already printed?Hey~!! It's a hobby. It's not supposed to make sense~!!
Reply:I hate you I really want any of the Fabricator line. Nice work I want 1 very bad now.
Reply:I have the 252 and love it. Haven't got the chance to use the mig (only have an argon bottle) stick and tig welds very nice Attached Images
Reply:Tig root with the 252 Attached Images
Reply:So what ground clamp did you get the tweco brass one or the plated with copper strap post a picture
Reply:The supplied  work clamp is  stamped and bent up  sheet metal  with copper tips.It'll serve prolly just fine, but it's not the one in the picture.They can't show you one thing and provide you another.Hey~!! It's a hobby. It's not supposed to make sense~!!
Reply:Originally Posted by ron.chapmanTig root with the 252
Reply:Yeah a lil bit just a lil bit practice practice and more practice
Reply:Originally Posted by MilkermanSo what ground clamp did you get the tweco brass one or the plated with copper strap post a picture
Reply:Originally Posted by ron.chapmanI got a brass one but its kinda dinky matter of fact the stick leads are dinky too. For it being a "300 amp" machine
GMT+8, 2025-12-29 13:03 , Processed in 0.112284 second(s), 18 queries .
