pipe land question
发表于 2021-8-31 22:48:50 | 显示全部楼层 |阅读模式
what size land would you use on a sch 40 2" and 4" pipe using 3/32 or 1/8 6010 rod
Reply:Depends on you, last wps I read stated 1/16th +/- 1/32, try different fitups to get what works for you
Reply:Depends on what you use for root gap and amperage for those rods.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I prefer a 1/8" land 1/8 6010. Maybe 90-95 amps, I just set dial by puddle. Then it burns my 7018 ( 3/32) like butter...My test was 3/32 land, had to whip root in so I wouldnt blow it apart...Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
GMT+8, 2025-12-29 13:04 , Processed in 0.073927 second(s), 18 queries .
