查看: 2|回复: 0
Remember these?
发表于 2021-8-31 22:48:49 | 显示全部楼层 |阅读模式
The engine stand mounts.....I have 45 to weld up and probably won't see this part again for a year......Last edited by B_C; 04-15-2013 at 07:00 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by B_CThe engine stand mounts.....I have 45 to weld up and probably won't see this part again for a year......
Reply:Mild steel I'm pretty sure......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Are these for displaying engines? They don't seem practical for working on an engine, you couldn't pull the heads or roll the block.
Reply:Based on the print on the flange and the way the flange looks they're for a ford flat head. Exhaust ports are part of the block not the head. And with the angle that tube is welded on I bet you can spin the motor perfectly fine.Brad GeorgeCurrent Equipment:AIRCO Heliwelder IV 300Amp Model - Total Awesomeness!Old 120v Hobart Handler MIGVarious grinders, cutting tools, hammers, clamps, ect..."I'm an amateur welder with lots left to learn..."
Reply:Here's the Flathead Jack's catalog page for this engine stand bracket:http://flatheadjack.com/143.html Attached Images"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Nice Tig work! Do you start in the crease, or the open angle?Looks like 2:00 or so on the open end...how many stops/starts, if you don't mind my asking?Motorboating...in the Cleavage of the Tetons
Reply:Beautiful as always.
Reply:Originally Posted by ironmangqAre these for displaying engines? They don't seem practical for working on an engine, you couldn't pull the heads or roll the block.
Reply:Originally Posted by rideitNice Tig work! Do you start in the crease, or the open angle?Looks like 2:00 or so on the open end...how many stops/starts, if you don't mind my asking?
Reply:Originally Posted by OldendumHere's the Flathead Jack's catalog page for this engine stand bracket:http://flatheadjack.com/143.html
Reply:Pretty cool man, my dad has bought a ton of stuff from Flathead Jack I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:as always best work from B_Cdo you finish the 40 in one day or 2 relaxed ones?--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:I can do it in one day no problem....takes 6.8 minutes per part...  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
GMT+8, 2025-12-29 13:04 , Processed in 0.093428 second(s), 18 queries .
