hello all-im looking into getting a arc welder but cannot find any info on a thermal arc 250-tr ac/dc and ideas on price? thanksLast edited by Osirus; 04-17-2013 at 04:31 PM.
Reply:Originally Posted by Osirushello all-im looking into getting a arc welder but cannot find any info on a thermal arc 250-tr ac/dc and ideas on price? thanks
Reply:Looks roughly like a Miller Dialarc 250 stick welder, spec-wise."USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:thanks for the info i cant find chit-- lets hope it works- looks like i bought it- might end up burning me cost me 271.00 ill pick it up tomorrow. lets hope that it works, it looks really cleanon the other hand i only have to finish my open root class and ill be done with my SMAW classes and will move on to mig or tig. i laid down some sweet stringer 7018 overhead today.... oh yea. Last edited by Osirus; 04-17-2013 at 05:12 PM.
Reply:There is not much to those. If it don't work, folks here can probably walk u through fixing it. Incorrect wiring from the power supply cable is the most common problem...Tiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:sweet, i figure ill pick it up tomarrow afternoon- not sure if it has a ground or stinger, either way its bought. then i just need to grab some electrodes and do some patching on my scout.I will let ya know what happens after i pick it up.
Reply:You can probably find a manual for it on Thermal Arc's site if you drill down enough. That beast will probably weld far better and longer than you will. Good luck!"USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I already downloaded and read through most of the manual, I'll give the thermal arc a good look and cleaning before i test it out. i hope it does weld for a long time as i have plenty of stuff to do with it.
Reply:I have bought several at action which seeing the tag on the front leads me to believe that is how you got this one. You must be close to me too as I see the Roller logo. I might have even bid on that one in the last auction... Never had a total Dud. often takes a bit of cleaning and as I mentioned make sure its wired for correct phase and voltage and all the connections are tightIf it turns out to be a dud just throw it back in the next auction. you won't get all you money back but can cut your lossesLast edited by soutthpaw; 04-17-2013 at 09:22 PM.Tiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:got it, im a little sad- someone decided to cut the power cord- maybe it was directly tied in? although it looks to be wired for 3 phase- which is a little weird since on the bill of sale shows single phase and all the info i could find shows single phase too, who know's ill take it apart this weekend and see what the truth is. Now i need to get a ground and stinger, that thing is super heavy it was almost too much for my brother and i to take out of the back of the pickup. on a side note im doing overhead 7018 bevel groove with back strap, i have cut and welded several 1/4" plate steel with backing strap and 37 degree bevel, so far after gouging out the backing strap and cutting down to 8"x1.5" strips then polished, i keep getting porosity i would assume down the groove of a weld, the porosity is super small spots but it just wont do- thinking it might be long arc? I have another i did today they just need to be polished and if clean a bend test. any ideas folks, sorry no pics im using 120 ams and also clean after each weld with a wire wheel machine. thanks |
