WTB: Tig Torch
发表于 2021-8-31 22:48:46 | 显示全部楼层 |阅读模式
I know someone has a used tig torch they don't need any more and are willing to let it go for cheap.  I'm trying to convert my 100 amp Lincoln Invertec V100-S to a DC tig until I can afford a larger machine.  Either air cooled or water cooled is fine.  I'd also prefer if the gas hose was separate from the power line, but I'm sure there are dinse adapters if needed.  Thanks
Reply:Where are you located?? I have an air cooled torch from my Invertec 205.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Oh shoot I forgot to mention I'm in Huntington Beach, CA.
Reply:Originally Posted by iWeasel410Oh shoot I forgot to mention I'm in Huntington Beach, CA.
Reply:Hahahaha, Paul I think I met you at ZTFab's welding class.  I'm the guy who brought the inverter stick welder   You're about 2 minutes from me, I live on Beach and Edinger, next to the 405!
Reply:Originally Posted by iWeasel410Hahahaha, Paul I think I met you at ZTFab's welding class.  I'm the guy who brought the inverter stick welder   You're about 2 minutes from me, I live on Beach and Edinger, next to the 405!
GMT+8, 2025-12-29 13:03 , Processed in 0.115330 second(s), 18 queries .
