need ideas
发表于 2021-8-31 22:48:43 | 显示全部楼层 |阅读模式
Hello everyone,Hope everybody's fine. I recently bought a miter saw (for wood... sorry) and i would like to build a stand on casters for it to move it around ...First, I'm hesitating between a "straight" simple rectangle or a slightly "slanted" design.What would you do ? I would also like to have some "wood rests" on each side, foldable and adjustable so i can  level them to the saw table height for longer / heavier pieces of wood.I was thinking of something with a piece of threaded rod ... or just sliding them into the frame tubes (like some work table extensions) but then it wouldn't be "foldable" ...I know you guys have amazing ideas and skills, maybe you could help me...thanks in advance
Reply:some quick plans for better understanding "straight" and "slanted" (don't know if it's the proper term Attached Images
Reply:Nothing wrong with building a stand. I don't know if you'll come in too much cheaper than some of the ready made stand/carts. A number of manufacturers sell variations on the stand below for varying amounts of cash. While a stand is nice, I would never go back after buying one for my compound miter saw that folds with the saw attached, has built in outriggers and wheels around like a shop carthttp://www.lowes.com/pd_237980-46069-ST0603W_0__The one I purchased...probably discontinued by now. Everything folds down and remains on cartLast edited by WyoRoy; 08-05-2013 at 01:23 PM.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:Tackit has a good idea: http://weldingweb.com/vbb/showthread.php?t=294241
Reply:I made a stand with splayed legs for my Dewalt Abrasive chop saw:It is made from 1-1/4 x 1/8 angle, looks flimsey but it isn't - it is quite stiff and stable.  Size your wheels according to the floor or gound you want it to roll on.  My tiny steel wheels roll best on clean well-swept smooth hard floor.  Suck on rough blacktop. Don't roll at all on gravel or turf.  IIRC the splay angle is 10 degrees.  Makes for improved stability when height exceeds length and width.- MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:thanksfor your quick answers, as always There are a few stands you can buy here of course, and they are of course cheaper than building one yourself (except the ones i've seen are not so elaborated).but you can beat the pleasure of building something yourself, exactly how you want it, and that will probably outlast anything you can buy ;-)Of course, tackit stand is great but the other design seems easier to doI built a stand for my cold saw similar to that, with straight legs not "splayed" and i was wondering about the reason of such a design, is it much more stable, even for a saw that is only a few kilos?
Reply:oups sorry, i hadn't read your message carefully enough mondo !!!Yeah, the height will be over the width (still building high stuff for my f... bad back)so definitely, splayed legs then
Reply:Originally Posted by uintas.., is it much more stable, even for a saw that is only a few kilos?
Reply:good point !
GMT+8, 2025-12-29 13:03 , Processed in 0.114737 second(s), 18 queries .
