New welder trailer
发表于 2021-8-31 22:48:42 | 显示全部楼层 |阅读模式
So of you might remember the body I made to mount my Big Blue Air Pak on the back of my Mazda. Well it was to much for the Mazda so I build a trailer for the welder. I think in the long run it will better having the trailer particularly if I get work on a mine site. I'll be able to hire a Mine Spec vehicle that complies to the site I'll be working on to tow the welder on site. I will be putting a frame on the front of the trailer so I can store gas cylinders and it will also keep mud and stones from getting thrown up at the welder. Please excuse the mess in the shed. The old man is rooting around building another mud racer and has **** everywhere.
Reply:WOW that is a nice clean trailer. Nice welder too. I would be proud to tow it behind my truck.  "G"ConductorX - The Volkswright Shophttp://volkswright.blogspot.com/http://bugwerks.blogspot.com/Miller DVI w/Spoolgun - Miller Plasma Cutter
Reply:A great looking trailer!JackFort Loramie, OhioMilermatic Autoset 180
Reply:awsome!Thermal Arc 186 AC/DC Tig SystemMillermultimatic 200 with spool gunFisher Norris 124lbs AnvilLiebherr Mining and Liebherr Nenzing Craneshttp://www.etsy.com/shop/ShootAphoto
Reply:Very nice work.. The yellow p/u in the back ground, is that an old Datsun 620???
Reply:Awsome! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by Thats HotVery nice work.. The yellow p/u in the back ground, is that an old Datsun 620???
Reply:Very nice work! Now, lets see more pics of the welder and the truck."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Nice set up. Is that cable going to the front the break away? How does it work? Never saw a setup like that. Are those commercial axles?
Reply:That is for the park brake. The service brakes are electric with a mechanical park. I also have to fit a breakaway unit that holds the trailer brakes for 30 seconds. As for the axles 45mm square with ford bearings and running 6 stud hubs. I'm not sure what you mean by commercial axles.
Reply:I see you decided to take it off that truck. Nice call. You will be thanking yourself later when your not replacing broken leaf springs.
Reply:Beautiful Trailer!!!
Reply:That's a great set up, quite a beast. I'm sure it will serve you well. You should be proud. Great work!
GMT+8, 2025-12-29 13:02 , Processed in 0.117710 second(s), 18 queries .
