Toilet Paper Your Proud Of!
发表于 2021-8-31 22:48:41 | 显示全部楼层 |阅读模式
This is a project that recently popped on my head so i decided to make it! Tell me what you think!The base is 1/8th stainless steelThe upright is 1/2inch mild steel square stock.The weld is done with Bronze silica, I recently purchased a pound of this rod to give it a shot and this was the first thing I tried it on. Attached ImagesThermal Arc 186 AC/DC Tig SystemMillermultimatic 200 with spool gunFisher Norris 124lbs AnvilLiebherr Mining and Liebherr Nenzing Craneshttp://www.etsy.com/shop/ShootAphoto
Reply:Virginia, that is a mad cool idea bud! But if your gonna be a bear, be a grizzly! Don't shut that torch off bud and go twisty nuts bro!  Attached ImagesI hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:base should be turned 90 to better resist the forces of pulling off the paper..
Reply:the base is weighted!Thermal Arc 186 AC/DC Tig SystemMillermultimatic 200 with spool gunFisher Norris 124lbs AnvilLiebherr Mining and Liebherr Nenzing Craneshttp://www.etsy.com/shop/ShootAphoto
Reply:Originally Posted by weldermikeVirginia, that is a mad cool idea bud! But if your gonna be a bear, be a grizzly! Don't shut that torch off bud and go twisty nuts bro!
Reply:That's gonna be hard to reach on top of the sawhorse not to mention what the neighbors think when you try it out .
Reply:Originally Posted by BD1That's gonna be hard to reach on top of the sawhorse not to mention what the neighbors think when you try it out .
Reply:I like it, but I can't believe you put the roll on wrong. Everyone knows it's over the top not behind.
Reply:Originally Posted by welderjI like it, but I can't believe you put the roll on wrong. Everyone knows it's over the top not behind.
Reply:so much arguement on how a toilet paper roll holder should be... LMAO!  apparently only the US is adiment about over the top... As for the base? function testing is in order. and turning the base might prevent it from fitting into the space between the toilet and wall/cabinet/etc.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Virginia,If your housemates are all welders I suggest you add two or three more rungs to hold rolls. you know, for the emergency days. LMAO.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:You need a "Loo Lizard".  http://www.thomaswestra.com.au/sculptures.htmReally clever stuff ... Attached Images"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:hahah thats pretty sweet!Thermal Arc 186 AC/DC Tig SystemMillermultimatic 200 with spool gunFisher Norris 124lbs AnvilLiebherr Mining and Liebherr Nenzing Craneshttp://www.etsy.com/shop/ShootAphoto
Reply:If you've got any cats in the house, you'll QUICKLY learn to put the end of the toilet paper roll at the back!!!  That way, when they try to claw at the roll and spin the whole da*m roll off on the floor, it'll just spin round 'n round.  If the end is on front, they WILL peel the whole roll off in nice big wad on the floor. How's that for a welding subject??
Reply:Personally, I'd like to see them start making brown toilet paper.Would make it easier to reuse it."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammPersonally, I'd like to see them start making brown toilet paper.Would make it easier to reuse it.
Reply:Originally Posted by shortfuseIf you've got any cats in the house, you'll QUICKLY learn to put the end of the toilet paper roll at the back!!!  That way, when they try to claw at the roll and spin the whole da*m roll off on the floor, it'll just spin round 'n round.  If the end is on front, they WILL peel the whole roll off in nice big wad on the floor. How's that for a welding subject??
Reply:i have not used TP in years at home. wet wipes are where its at. Hell, i'd steal a swiffer wipe in a pinch, after a pinch.
Reply:Originally Posted by Jimmy_popi have not used TP in years at home. wet wipes are where its at. Hell, i'd steal a swiffer wipe in a pinch, after a pinch.
Reply:yeah, I'm on a septic system. Wipes don't go down the drain, therefore they don't get used for that.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Bet ya didn't know Medicare requires all facilities receiving Medicare dollars to use 2 ply toilet paper.Medicare requires a copy of all paperwork done.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Originally Posted by MarkBall2... Medicare requires a copy of all paperwork done.
Reply:Originally Posted by ThorsHammerVirginia,If your housemates are all welders I suggest you add two or three more rungs to hold rolls. you know, for the emergency days. LMAO.Originally Posted by OldendumThe dark copy or the one underneath?
Reply:Originally Posted by wellolike this one i made a while back
Reply:When toilet paper is used properly , it makes putting underwear on foolproof. Yellow is front, brown is rear.
Reply:Originally Posted by BD1When toilet paper is used properly , it makes putting underwear on foolproof. Yellow is front, brown is rear.
Reply:Originally Posted by weldermikeEeeew! Don't drink to many keystones and put em on your head with the brown skidmarks in the front!
Reply:very nice!!! what type of finish is that? just paint?Thermal Arc 186 AC/DC Tig SystemMillermultimatic 200 with spool gunFisher Norris 124lbs AnvilLiebherr Mining and Liebherr Nenzing Craneshttp://www.etsy.com/shop/ShootAphoto
Reply:Originally Posted by ThorsHammerIn my parent's house and in my adult house I've always had two cats, and have always been told by the wardens of those establishments that the rolls need to come over the top (mom even wrote a paper about it when she was going through college at 40 yrs old) and never once has a cat unrolled the TP.... The toddlers on the other hand.
Reply:We all have it wrong and horses and cows get it right....the roughage they eat turns into toilet paper on the way out . cue the music......wipeout
Reply:Originally Posted by Virginiavery nice!!! what type of finish is that? just paint?
Reply:How about this one? Attached ImagesScooterLincoln Weld-pak 155 - .030 Solid wire & 75/25 gas mixMiller Thunderbolt 225Hypertherm PM 85Thermal Dynamics cutmaster 38Gas ax with rose bud attachment
Reply:I think this topic needs to go down in the "annals" of weldingweb history maybe even make it a sticky...
Reply:Originally Posted by weldermike But if your gonna be a bear, be a grizzly!
Reply:Originally Posted by DieselDon16Is Someone a Justified Fan????
GMT+8, 2025-12-29 13:04 , Processed in 0.100274 second(s), 18 queries .
