Simple Pipe Jig
发表于 2021-8-31 22:48:40 | 显示全部楼层 |阅读模式
A couple of crossbars on the baler need welding, and I've needed something like this before.  So a quickie throw togetherPiece of angle is welded to a piece of tubing to provide a flat surface for a C clamp, and to further stiffen the assembly.Then it's flame straightened to compensate for the distortion caused by the welding.  Just 6 small welds is enough to pull it out of true.Two top clamp thingies are made in the same fashion, but with smaller angle so that I can handle pipe/stock diameters as small as 1/2".And there you have itThe Uranis model 111 pipe jigIt will handle up to 6" pipe, which is probably as big as I'll ever need.  I'm pretty sure there's something from Ridgid or somebody that will accomplish the same thing, but the price of mine can't be beat.  It'll simplify alignment and tacking enormously.Might even get some hay baled this year...........or not (thinking of mowing it all and leaving it due to the weed load caused by the wildfire last year)"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I like it. I have used drops of square tube before. How about notching the long piece of angle so you can weld around more than 1/3 of the pipe?If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Cool Samm, not bad for tack up work. Now all you need is a few pipe roller stands and a positioner and then your in business! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Nice! But for goodness sake paint and grease that vise!!!!!!!! It's bugging the crap out of me. Everyone of your threads I look for the vise before I look at your project.
Reply:That's a pretty badass welding table and vise.
GMT+8, 2025-12-29 13:04 , Processed in 0.101111 second(s), 18 queries .
