Victor torch id
发表于 2021-8-31 22:48:39 | 显示全部楼层 |阅读模式
Wanting to buy a Victor torch I had a guy send pictures of one model number looks to be OA 7250 cutting head says 1-2-101 any help identifying what model Victor this is or any numbers close to what I posted?Quote Originally Posted by vwguy3  View PostHave you ever seen a cow that was welding overhead burst into flames my certs as of 1/29/14SMAW3G plate 2,4,6, 6Ghard wire and flux core 3GGTAW2,4,6 6G3G plate SS sch 80 6G
Reply:The numbers he sent you are the tip size on that torch
Reply:It's a heavy duty Victor torch. It uses the larger Victor tips is all. His numbers are a little backwards. The tip is a 1-101 series size 2 or 2-1-101. The medium duty torch uses 3-101 tips. Depending what you need it for a lot of guys prefer the smaller med. duty torch.
GMT+8, 2025-12-29 13:03 , Processed in 0.113485 second(s), 18 queries .
