Welding contact question!
发表于 2021-8-31 22:48:37 | 显示全部楼层 |阅读模式
alright so i stick my electrode stuck sometimes and i sometimes cant clamp the work piece down so is it safe (with gloves on of course) to put the piece of metal off and also rest on the table but the table is grounded
Reply:Originally Posted by farmwelderalright so i stick my electrode stuck sometimes and i sometimes cant clamp the work piece down so is it safe (with gloves on of course) to put the piece of metal off and also rest on the table but the table is grounded
Reply:I think we need a video Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by MinnesotaDaveI think we need a video
Reply:Are you worried about getting shocked?  Unless you are soaked with sweat you will be fine. You can hang all over your work and even touch the electrode.Try re-wording your post. It is very confusing. Dan D.Last edited by DanD78; 12-16-2014 at 11:21 PM.Manipulator Of Metal
Reply:Like a guy that posts like that has any time for video..lmao
Reply:Are you asking if you can ground your workpiece with your hand?  Not advisable or likely with gloves.If the table is grounded and you don't get in the middle go for it
Reply:If you don't have clamps, which most of us never have too many of, tack the piece down to the table w/ one small tack. When finished or you need to change position just break the tack by twisting the workpiece.                                                        MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:I think he is trying to say, after sticking rod to what he is working on, will he get shocked ir he moves the item to be welded to another area to unstick while holding on to the grounded table. I personally would say , no you won't receive a shock, having done the same thing.RegardsDave
Reply:If the rod sticks, just release it from the stinger.  Break it off, and start over.My name's not Jim....
Reply:Originally Posted by smilindaveI think he is trying to say, after sticking rod to what he is working on, will he get shocked ir he moves the item to be welded to another area to unstick while holding on to the grounded table. I personally would say , no you won't receive a shock, having done the same thing.RegardsDave
GMT+8, 2025-12-29 16:30 , Processed in 0.082282 second(s), 18 queries .
