where to get a bead roller?
发表于 2021-8-31 22:48:36 | 显示全部楼层 |阅读模式
im looking for a bead roller. not for sheet metal. but for tubing. mostly 2.5" - 3", no thicker than 1/8 inch wall thickness steel and aluminum.anyone can help me here?Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:Try www.eastwood.com I think they have a bead roller for tubing. Not sure about the cost, though.
Reply:i second eastwood, they are good guys, pretty good stuff, very helpful
Reply:You need to look up a tool called Bead Form.  I think trick tools usually has them on ebay.  The are purposely made for tubing.  http://www.beadform.com/I have one that goes from 5/8 to 2" and have used it on stuff up to 4".  I have also abused it on stuff like .065 wall stainless - wouldn't want to do it often, but it got the job done!
GMT+8, 2025-12-29 13:03 , Processed in 0.352621 second(s), 18 queries .
