What is this ring for?
发表于 2021-8-31 22:48:34 | 显示全部楼层 |阅读模式
Hey guys, what is this ring on the ram used for on this style press?  Sorry for the dumb question...just I havent seen this design before.  Its for sale locally.  I think Im going to go check it out.  It's listed as a 60 ton press.Miller 210Lincoln AC225-sHypertherm Powermax 600
Reply:its used for lowering down or up. like a screw jack, then you pump the handle
Reply:Yup - used to take up the slack between the ram and work piece so you don't have to jack all day before making contact.60 ton is a pretty big press.  Should do ANYTHING you might have to do around the house that's for sure.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks,  I see now that there are presses that have adj tables and I guess there are some with adj rams.  Yea if you saw my post below....you know im looking to bend 1/4 steel plate.Miller 210Lincoln AC225-sHypertherm Powermax 600
Reply:WOW !! that thing should be able to press coal into diamonds !!1 HAHAahahhhahhaAWS certified welding inspectorAWS certified welder
Reply:Originally Posted by halltrailThanks,  I see now that there are presses that have adj tables and I guess there are some with adj rams.  Yea if you saw my post below....you know im looking to bend 1/4 steel plate.
Reply:My dad has an old press like that in his mechanic shop, which he enherated from my grand father.The picture dosent show the hand pump,but it should be overhead on the right side with the release valve next to it. Its the only one like it I have ever seen until now. If the price is right buy it.It will probably out last you.Last edited by busyman; 09-24-2008 at 10:30 PM.
Reply:Make sure you use the proper V blockes when bending small plates.If the metal is not secured properly it can squirt out and hit you in the face.AWS certified welding inspectorAWS certified welder
Reply:My dad has one of those too. It has a handle that has a drive that dogs into the top side of the hand wheel to turn it, and a hydraulic cylinder.  Its a good find.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Well, I ended up picking up this monster.  I also picked up a Dake 25t press.  I actually got that first but it wasnt working so I got the 60ton.  Two days later, I fixed the Dake, turned out someone had plugged the exhaust port - duh.  Took the plug out and it works like a charm.The 60 ton actually has two levers on the right. One is fast action and the other is slower.  It also has a 5 ton manual press on the left side.  It is pretty damn cool  Ill probably end up selling the dake...and use the money to get a milling machine.Here are some pics:By the way, Im not a Ravens fan....That belongs to the wife.Miller 210Lincoln AC225-sHypertherm Powermax 600
Reply:halltrail, Those are some pretty heavy-duty presses you have there.btw, the dual levers (pumps) are not just a matter of fast and slow but the 'slow' pump allows you to achieve the 60T capabilities of that bad bear.  It would be almost impossible to develop the pressure required to exert 60T of pressure with the high volume (fast) pump due to the pump-to-ram displacement ratio.Some nice lookin' gear in that shop.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Nice presses.  My welders are NOT TOOL BENCHES!  Apparently a pet peeve of mine.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Duane, Thanks and you are right....Ive noticed that the "slow" one is the one that allows me to develop the higher pressure.....not necessarily move slow.... :-)Hey Dave, I dont like to use it as a tool bench either...you caught me at a bad moment     ....but if it makes you feel better....what is on there are my welding gloves, and various clamps used for welding....and I think that is the user manual on there too.  Im hoping to start making a few dies/punches this weekend.Miller 210Lincoln AC225-sHypertherm Powermax 600
Reply:Originally Posted by halltrailDuane, Thanks and you are right....Ive noticed that the "slow" one is the one that allows me to develop the higher pressure.....not necessarily move slow.... :-)
GMT+8, 2025-12-29 14:57 , Processed in 0.073473 second(s), 18 queries .
