Flux core wire
发表于 2021-8-31 22:48:30 | 显示全部楼层 |阅读模式
I was curious what  a good general purpose, all positions flux core wire ( gas less ) was?  I thought I read somewhere 1 alloy works better for vertical and overhead and another for flat. I've ran a lot of .035 er70s-6 but never any flux core. I usually weld mild steel 1/8" to 3/8" and occasionally up to 1". I was curious about the flux core and wanted to give it a try. Any suggestions would be great!Miller Bobcat 225AHP AlphaTig 200X
Reply:I don't do much flux core, but Lincoln NR-211-NP was recommended by Dan, IIRC, a long time member here and at Weld Talk.  I run .035 in my HH140 and HH187.  You should be able to get the 8" spools at Home Depot or Lowe's.http://www.lincolnelectric.com/en-us...olnElectric%29
Reply:Originally Posted by copeI don't do much flux core, but Lincoln NR-211-NP was recommended by Dan, IIRC, a long time member here and at Weld Talk.  I run .035 in my HH140 and HH187.  You should be able to get the 8" spools at Home Depot or Lowe's.http://www.lincolnelectric.com/en-us...olnElectric%29
Reply:With the limited knowledge I have of it, you will either want an E71T-11 or E71T-GS. Hobart's version of the E71T-11 is the Fabshield 21B, and the GS is Fabshield 23. You can get good info from the Hobart Brothers site.I think, the GS wire is more limited to thickness of material and to single pass. My limited usage of FCAW-S is with the 21B. I actually liked it, from the little I've used it."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Thanks for all the input. I'll try the e71t-11 and see how it goes. Thanks again for all the help.Miller Bobcat 225AHP AlphaTig 200X
GMT+8, 2025-12-29 13:03 , Processed in 0.070531 second(s), 18 queries .
