surfacing of CS with Stellite
发表于 2021-8-31 22:48:29 | 显示全部楼层 |阅读模式
Hi every BodyI want to hard facing of check valve with stellite 6. i heard that one layer of inconel 625 shall be deposited at first.if this subject is right what is the function of this layer and do you have any reference?Thanks!
Reply:From what I read, it is relatively common to use a soft base layer under hardfacing, especially to rebuild worn away material. Hardfacing is relatively brittle (depending on type), and a soft base layer reduces the risk of cracking.At other times a "basecoat" may be used simply because the hardfacing does not work well straight on the base metal. You add a layer that welds well onto the base material, and in turn, the hardfacing welds well onto that.I have no idea if that's the purpouse of a layer inconel 625, or what properties that has, but if it's supposed to be there I'm guessing the reasoning is something along those lines.
Reply:Look at the information in the second post here:http://hghouston.com/Resources/Discu...s/Default.aspx"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I used to wear a "Hot Shoe " when I raced Flat Track that was hard faced by Ken Maley the Hot Shoe Man we wouldn't have to have it redone for years.......and that was thirty races a year setting down on the dirt at 100 mph multitudes of times a race  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
GMT+8, 2025-12-29 13:03 , Processed in 0.089197 second(s), 18 queries .
