Stainless pipe lamp
发表于 2021-8-31 22:48:21 | 显示全部楼层 |阅读模式
Here is a lamp I made out of stainless 3" pipe and 1/2" plate.This was my first attempt at stainless tig. Attached ImagesTOO MANY TOOLS & NO MORE SPACE
Reply:I like it!  good job.  stainless is pretty tricky to those who don't play with it very often.
Reply:Nice lamp. Very industrial looking. Attached Images
Reply:The tie rods make it look like a hydraulic cylinder.  How funny would that be if you could raise and lower the lamp hydraulically.
Reply:Welding/Fab Pics: www.UtahWeld.com
Reply:Thanks to all for the comments. Originally Posted by bullfrogg0I like it!  good job.  stainless is pretty tricky to those who don't play with it very often.
Reply:you just have to be mindful of your heat input while welding stainless.  don't hang around in one place too long or have the heat up too high or you'll burn the chrome out and it turns a sort of dull grey instead of shiny at which point it has lost it's corrosion resistance and can actually rust
Reply:Neat. Don'i have to worry about it leaking.
Reply:Nice clean lines ... good job!http://www.facebook.com/LockhartMetalArthttp://www.facebook.com/pages/Grumpy...44306259043484
Reply:Another incredible piece! This is a very good example of being creative and resourceful! You outdid yourself! Like the idea of using a stainless pipe.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Wonder if  it'll support the lampshade OK? POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:Originally Posted by SMC WeldcraftWonder if  it'll support the lampshade OK?
GMT+8, 2025-12-29 13:03 , Processed in 0.085144 second(s), 18 queries .
