TIG torch failure
发表于 2021-8-31 22:48:19 | 显示全部楼层 |阅读模式
Embarrassed to admit I wasn't aware it even happened, only that it was drooped the next time I used it!This is a new one for me usually I wreck hoses. Looks like over heat but why...standard no. 20 CK water cooled torch (labeled Weldmark) rated for 250 amps. Coolmate 4 water cooler that I checked for flow and I got a quart in 35 seconds from the water return/power line so I don't suspect the cooler. And I never maxed out on amps with this torch. Go figure.The fix: CK Master series and some super-flex hoses
Reply:Nice fix!Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
GMT+8, 2025-12-29 13:03 , Processed in 0.079228 second(s), 18 queries .
