First Wire Welder
发表于 2021-8-31 22:48:18 | 显示全部楼层 |阅读模式
okay so it needs to be able to run flux core, can be 220, preferably under $500, and needs a good duty cycle like 50% at mid amp range. any suggestions
Reply:I think you'll find a 220v fcaw/ mig(which most 220v are both) machine will be hard to find even used. A 110v fcaw  new maybe. I suggest looking for a good used 220v, preferably red, blue or orange.                            MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:What kind and size of flux-core? How thick of material do you want to weld? I don't know if you'd find something under $500 if you want to weld say 3/8" plate with a decent duty cycle.
Reply:Hobart Handler 190 comes to mind. You can catch them for about $500 on e-bay.http://www.ebay.com/itm/HOBART-Handl...item259c19b04eGety one that has a gas valve so you can run solid wire at some point would be my suggestion.
Reply:Yeah, HH190 is a good choice.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:I thought this was going to be an old welder or first wire feed welder made thread.  I think it was AIRCO that made the first working and patented wire feeder. So, plus 1 on used red, blue or orange.Southpaw recently explained to me about spray transfer. He said you need about 180 amps minimum.  I believe him so you would need 220v machine.Any body got any advice about a machine to use for spray transfer.
Reply:Originally Posted by InsanerideAny body got any advice about a machine to use for spray transfer.
GMT+8, 2025-12-29 12:56 , Processed in 0.359156 second(s), 18 queries .
