Ooch! That's got to hurt!
发表于 2021-8-31 22:48:17 | 显示全部楼层 |阅读模式
I don't know if this has been posted on here, sent to me by a buddy, if so I apologize.https://scontent-a-ord.xx.fbcdn.net/...a2&oe=55364CE8
Reply:That thought goes through my mind when ever I move one of my engine drives with the forks on the tractor. I just couldn't stand it anymore, so now I use a ratchet strap to secure the welder so it won't slip on the forks.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:The welder looks like a new SAE300. If it was older SA200, it would probably start right up like nothing happened.
Reply:Originally Posted by 7A749I was moving a Deltaweld 450 with a forklift when I had my shop and it slipped back as I was trying to put it on a high shelf. It fell about six feet and landed top side down directly on top of a very nice Miller Bluestar 2E engine drive machine.Totally smoked the top sheet metal piece of the Bluestar and totaled the Deltaweld. The pic in the link is a whole lot worse tho
Reply:That was plenty ugly. And no doubt VERY costly. I saw a similar screw up with a 55 ton Grove RT. Bozos went 6 part line without checking to see if the had enough rope on the drum to reach the ground with the boom at full extension. It was only a 750HP vertical hollow shaft motor that they destroyed. Nothing like that turbine rotor.
Reply:Originally Posted by 7A749"I put it back and grabbed another one..." Big Boss Man: "Hey, Carl... What the hell happened to that welder??? Looks like it got rolled down a mountain!"Carl: " Geez, boss.... It's always looked that way.."
Reply:When you have a project this size going on, it's hard to keep track of all the equipment. Especially a welding machine.  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by 7A749Whoops!
Reply:Originally Posted by MinnesotaDaveHe was just seating the bearings
Reply:On that video I could not believe that the one guy was under it for a bit. I thought no one was to be underneath the load as it is in motion. He may have had to go home and changed his shorts after that turbine crashed, it would have killed him.HF 90 Amp Flux Core Customized.
Reply:Originally Posted by BrianCBet he used Plastigauge to check 'em!
Reply:i could have sworn the guy in carhart coveralls was underneath when it let goLast edited by docwelder; 12-25-2014 at 08:44 PM.i.u.o.e. # 15queens, ny and sunny fla
GMT+8, 2025-12-29 13:03 , Processed in 0.114256 second(s), 18 queries .
