Foot Shear Cap.
发表于 2021-8-31 22:48:15 | 显示全部楼层 |阅读模式
I'm getting a ToolsPlus1 52'' 16 gauge shear and wanted to know if it was like a brake. Can I shear thicker plate say like 1/8'' if its on 6'' wide? I know on brake you bend thicker material if its narrower. Thanks
Reply:i have the same ? im looking at the grizzly 52" shearits $995.00 + $250.00 im going to call them about thereanvils i will ask about that two Attached Images
Reply:Originally Posted by BryanDowdyI'm getting a ToolsPlus1 52'' 16 gauge shear and wanted to know if it was like a brake. Can I shear thicker plate say like 1/8'' if its on 6'' wide? I know on brake you bend thicker material if its narrower. Thanks
Reply:why not? will it break the blade or something.
Reply:Originally Posted by ace4059why not? will it break the blade or something.
Reply:Originally Posted by ed maci have the same ? im looking at the grizzly 52" shearits $995.00 + $250.00 im going to call them about thereanvils i will ask about that two
GMT+8, 2025-12-29 13:04 , Processed in 0.104333 second(s), 18 queries .
