vertical bandsaw - low buck/good quality?
发表于 2021-8-31 22:48:15 | 显示全部楼层 |阅读模式
i have seen a lot of good about the HF horizontal band saw. but sometimes you cant get that certain piece in a horizontal saw.anyone have a HF vertical bandsaw? if so, wich one do you recomend...if at all?any other good one out there for us poor garage guys?Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:oh...and i seen one that said horizontal/vertical? how does this work?  looked like a regular horizontal to me...Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:Originally Posted by sen2twoi have seen a lot of good about the HF horizontal band saw. but sometimes you cant get that certain piece in a horizontal saw.anyone have a HF vertical bandsaw? if so, wich one do you recomend...if at all?any other good one out there for us poor garage guys?
Reply:Originally Posted by sen2twooh...and i seen one that said horizontal/vertical? how does this work?  looked like a regular horizontal to me...
Reply:cool. does the HF one come with the table atatchment? thats a nice way to get a 2-for-1...seems like the HF one is good after you put in a lenox blade from home depot.Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:Originally Posted by sen2twocool. does the HF one come with the table atatchment? thats a nice way to get a 2-for-1...seems like the HF one is good after you put in a lenox blade from home depot.
Reply:thanks...its listed for 250 right now on there web site. i'll wait for it to come down. usually everything goes on sale in HF inside one month. you just have to wait for it.Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:If you dont need the reach of a vertical band saw. Like sawing a large piece. Use a Porta band in the vise. It has the ability to cut up to 4" material any length. Personally I wouldnt like having to reset my horizontal saw to a table so I can use it on odd shapes.I use my porta band in a vise all the time. It works exceptionall well on cutting curved sections from u bends. And is all I need for brackets and such. If you are cutting long strips about 2" wide is all it will do. Unlike a large vertical saw which starts at about 14" wide. Nice thing is its relatively inexpensive and has enough power to make most of the cuts needed.mm135HTP Invertig 201 With water cooler9" Southbend LatheLots of hand tools.
Reply:you have picture or a link to one of these?Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:Originally Posted by sen2twothanks...its listed for 250 right now on there web site. i'll wait for it to come down. usually everything goes on sale in HF inside one month. you just have to wait for it.
GMT+8, 2025-12-29 13:03 , Processed in 0.111466 second(s), 18 queries .
