Old Compressors
发表于 2021-8-31 22:48:13 | 显示全部楼层 |阅读模式
Gordon Stephenson posted some pics of his "old reliable" some time back.  Just got done tunin' mine up to paint my latest Scientific Marvel & Welding MiracleBurnt post(or something like that) in motor, so the motor repair guy said while handing me a bill for 52 bucks.  New pressure switch (old one leaked a little bit) $29Bought the ol' girl at auction about 15 yrs. ago.  Homebuilt on an old style propane tank.  High bid $70.  A newer Craftsman oiless unit sitting next to it went for around $175 just before mine went on the block.  They weren't lookin' when I bought this oneAny other "well worn" ones out there?? Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Hello Farmersamm, Looks like a useful machine,Nice size tank and good size wheelsm Is the comp single or two stage? May you both have a long and happy life, Recently stripped one of these new cheap chinese ones for a friend.It consisted of a motor with eccentric shaft driving a con-rod with a fixed alloy disc for a piston, the seal was a thin nylon? cupped washer, The whole thing is just a glorified bike pump, Can't buy a new seal on it's own, Probably use the tank as a portable for tyre blowing, Cheers  Gordon.,Last edited by gordon stephenson; 11-06-2008 at 05:24 PM.
Reply:Originally Posted by gordon stephensonHello Farmersamm, Looks like a useful machine,Nice size tank and good size wheelsm Is the comp single or two stage? May you both have a long and happy life, Recently stripped one of these new cheap chinese ones for a friend.It consisted of a motor with eccentric shaft driving a con-rod with a fixed alloy disc for a piston, the seal was a thin nylon? cupped washer, The whole thing is just a glorified bike pump, Can't buy a new seal on it's own, Probably use the tank as a portable for tyre blowing, Cheers  Gordon.,
Reply:As long as it puts out good air in good quantity, I'm sure it'll paint your cedar shifter and tint the dog, too"One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:Gordon-  Single stageTractapac-  IF I ever get to paint.  High winds for last 4 days.  Usually hook it up to an additional 40 gal. tank, turn the pressure shutoff up to 140, then have at it."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammIF I ever get to paint.  High winds for last 4 days.
Reply:Or shoot it from about 100 feet away UPWIND"Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-29 13:03 , Processed in 0.102872 second(s), 18 queries .
