'79 Blackface SA 200 Engine Valves
发表于 2021-8-31 15:02:09 | 显示全部楼层 |阅读模式
Had a question about adjusting valves on SA200 and saw a video from BWParts ()  on doing the adjustment but had a question. From what I saw in the video you can adjust the valves on Cylinder 4 when Cylinder 1 is at TDC and adjust 1 when 4 is TDC, same for Cylinder 2 when Cylinder 3 is TDC if I understand all this correctly. Correct me if I am wrong because I am not a mechanic but I have a toolbox of wrenches I use all the time. My question is, do you adjust both intake and exhaust at the same time for Cylinder 4 when Cylinder 1 is TDC or do you adjust all intake first and then adjust exhaust valves second using the same process outlined above. I have a vacuum\fuel pump gauge attached on Cylinder 1 and have it at TDC at the current moment. Head is not off of the engine, only the vacuum gauge is attached..012 clearance on intake.020 clearance on exhaustIf I ever get this first SA200 painted and rebuilt, my goal is to find myself a Redface and rebuild it as well.
Reply:I think I might have figured it out myself. Watched the video a couple of times and I here him make reference to setting "them" meaning intake and exhaust when you have a piston at TDC.
Reply:All you have to do is watch the the valves when turning the engine over by hand with a hand crank, and remember the firing order 1-3-4-2, this way you can see when both valves close at TDC, and the valve tappets are on the heel of the cam lobes. Make sure that when adjusting the exhaust valve that it has a slightly loose feel because of heat expansion. Always better to have a loose adjustment than a tight adjustment. If to tight, a valve or valve seat can get burnt out, and that goes for any engine.SA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
GMT+8, 2025-12-18 16:08 , Processed in 0.097460 second(s), 18 queries .
